- Aug 27, 2001
- 5,147
Any tips for installing the molded firewall insulation that the vendors sell? Having a hard time getting the rubber fasters/ plugs to slip through the holes in the firewall. The version I just got is from Jeffs and has the stock style rubber fasteners that slide through the firewall holes. The ones I used in the older molded insulation were plastic and had fins on it and pushed right through and stayed. On this kit...the rubber stock style...I 've tried pulling them through,but the tip rips off therefore ruining them. Seems no matter how careful...even when greased...I seem to end up pulling the tips off. I've even used a long thin Blount object to stick into the back side to push them through, but usually just forces out the tip as well. Any suggestions?
Thanks,
Blue71
Thanks,
Blue71
