I'm running a ZF + NP205 set up w/ dual exhaust. I ended up going under the driver frame rail and fabbed a skid plate to protect it. I already had some 4x4 angle iron bolted to the frame on each side, one to protect the fuel pump on pass side and the other to protect my OBA on driver side, so all I had to do was tie the skid plate onto them. I've since relocated my fuel pump closer to the tank.
Kind of a crappy fab job, but it gets the job done and protects the NP205 as well. Tied in some bracing to stiffen it up and the front ties to the BCB crossmember to toughen it. If I re-do the exhaust to a 2 into 1 setup, I'll probably run it just in front of the BCB crossmember and make another plate or use some square tubing to protect it there. Forgot to mention I also have Headman long tubes w/ ball type collector flanges.
Good luck! B2
