Nothing is etched in stone regarding Broncos as much as the fact that nothing is etched in stone.
Even the 7 and 6 numbers (the most common yardstick) are merely approximate. Broncos can easily be a half inch in either direction, or sometimes more, for a given amount of suspension height. Different options, different modifications, different ages, etc. All can make at least a little bit of a difference.
It's just the way they are.
So the tech that told you 7" at both ends was either correct from their own experiences, or simply not remembering it (the rule-of-thumb) correctly. Chuck from BC Broncos was the first to make this a well known measurement from what I remember. Probably got tired of all the "why is my Bronco half an inch lower/taller/wider/heavier/uglier/bluer than what you said it would be" comments.
So while your numbers may in fact be wrong, you might also be right.
The trick is not to sweat the precision too much.
