broncoman1972
- Mar 4, 2004
- 1,297
A couple of weeks ago the trans on my EB let me down. I suspect a failed converter but looking for input before pulling it out so I'll have a game plan. Here's what happened:
The previous times I've driven everything has been fine. No shifting issues, trans temp staying under 180 ish. Drove it to work on Friday and noticed the converter would not lock when I threw the switch. I tried a couple of times with the same result. When I got on the interstate I threw the switch but was hauling a** and didn't pay attention to if it locked up. After a few miles I noticed the trans temp was hitting 200+ for the 1st time ever. I unlocked the converter and the temp came down. Everything else was fine the rest of the way to work. After work when driving home I made sure not to lock the converter at all. About half way home (maybe 12 miles or so) on accel from a stop the trans started whining bad. It was all of a sudden. No noise before the stop. No odd jerks, bumps or anything either. I noticed a lack of umph almost immediately. It would whine only under load and went away on deceleration. The trans temp would go to 210 or so on accel the drop to around 200 at steady 59 mph. After one stop at a light it revved but didn't pull when I 1st hit the gas. Eventually it pulled and got me home. When I eased into the carport and tried to back up a but it stopped pulling again.
Yesterday I drained the fluid and pulled the pan. The fluid was not burnt and absolutely no metal was in the pan. There is a bit of clutch material and some water droplets (no doubt from my deep water rescue last year.) The only odd thing is that some of the material looks kind of an orange color. A pic is below but it doesn't do justice.
So. I'm thinking the converter let go. Hoping the pump wasn't damaged since the is no metal in the pan. Can anyone offer any input on if this sounds logical. I'm basically trying to determine if I should just drop the trans and replace the conversation. Also, should I pull the pump and inspect it? Or, should I pull the whole thing apart and go through it?
For those not familiar with my build it's a 4r70w, no computer, full manual reverse valve body with braking in all gears. It's got about 6500 miles on it since it was built. Also to note: the 1st RMVB wasn't successful (never got down my street), 2nd had some trouble that was determined to be the fact that I used a gasket when installing it so some holes didn't match up (only made it back and forth on my street before being corrected.) And lastly, I had to make an adjustment to the switch that energizes the solenoids that lock 4th gear. The were getting powered when shifting to 2nd causing a bad flair.
So what does the peanut gallery think?
Thanks,
Mike
Thanks,
Mike
