Probably 50 (or more) people here using full-width, for every person that shortens one.
Been done many times.
I'm assuming the extra grinding of the wedge removal is because pulling the tubes out of the housing/center section is not an easy task? Take some interesting tools and jigs I suppose, but I'm not sure.
If it's not easy though, then you're heading down the right path.
The only thing I would add though, is that you will also have to grind down the outer end of the tubes in the new position, to re-fit the steering yokes. If I'm not mistaken, the tube end is smaller where the "C" is pressed over it.
I'm sure others know more about that than I do, so will add what they know about fitting the yokes.
