Grinding Noise in Bell Housing area.
Workhorse69
Newbie
Springfield, VA
I have a hydraulic throw-out/ZF-5 mated to my 302 with a Centerforce Clutch installed.
I just picked up a new noise that I can’t identify the precise location/source of. The noise is a rhythmic grinding noise that varies in frequency and pitch. It also is there regardless of clutch engagement or gear or speed. Anyone have experience with this same problem?
I have opened up the engine plate a bit and shined a light to see if something stood out but I’m not seeing anything obvious.
http://vimeo.com/501954052?ref=em-share
Apogee
That sounds terrible...did you check that the springs in the friction disc clear the heads of the flywheel bolts? I had that issue on an engine I built and had to machine down the heads slightly to clear the larger spring diameter found on the CenterForce disc.
W
Workhorse69
Newbie
Springfield, VA
I did check the starter bolts and they were good to go. I did order new ARP bolts for the flywheel and pressure plate as I’m assuming I going to tearing this all apart. It was assembled with the original hardware and the bolts backing out was all I could guess.
I have around 200 miles on it after I first assembled and there was no issues then this kicked off, luckily it was only a mile from the house.
ngsd
My nv3550 makes a grinding noise that goes away when you press on the clutch. It is s common problem with those transmission bearings. Possible a trans bearing? I thought it was a throw out bearing but I just replaced it so I knew that wasn't the case. Good luck
SP73
I had this happen once, but about 40 miles from home! It started off sounding just like yours, but got much worse (louder).
c0astie31
I had a similar noise on mine at one point, it was the plate that goes between the engine and the bell housing, and it rubbed against the flywheel
reamer
Remember, ZF's are truck trannys and Chatter alot naturally
