zombie66
I know there is some great C.B. radio info out there but I had a couple questions I didnt see answers to.
1) Does anyone know if you lose transmitting / recieving power by using one of the spring loaded quick disconnects for the antennae? And same question for adding a spring to the antennae for trail use?
2) For those of you running full hard tops and C.B.'s. I just aqcuired a full top with a C.B. antennae hole in the middle front of the top that is currently plugged. My thought was to unplug it and run my antennae from the same spot but I wanted to check in and see if anyone had experience with this.
Pros:from what I've read it sounds like the perfect location and ground plane for a c.b. antennae.
Cons: bronco is always parked in the garage so do I use a disconnect? some sort of antennae mount that can flip down the antennae for storage?
Any ideas would help and be apreciated, thanks
Kevin
Kevin
