Gauge cluster refurbishing
fallingdown
fallingdown
chrlsful
As all ways, thanks 4 the pic, Kevin. I been tryin 2 figure out what radio goes w/my bronk 4 27 yrs. If U got it I'm pretty sure it's oem (or close enuff 4 this ol timer).
Gettin good w/the camera. Boy, this interest has taken U far. Now cameras skills, radios, boats, planes, dashes... Did I miss anything, it's been awhile.
LSUpete
Here is Perter O's gauge. This is the second cluster I have done for Peter.
That is correct. Kevin has done TWO for me.....because he is a detail oriented craftsman who does great work.
Thanks again!
Monster Mike
Can you install mechanical gauges for oil pressure & water temp?
Also I pulled a cluster from a 64 F100 its a perfect match to the bronco. I think I'd like to send that one to you if you think it will be a good donor
vintage bronco
Here is the gauge cluster I refurbished for Barry F. Barry wanted his outer bezel chrome plated. The pictures don't do this cluster justice.
I can say this cluster turned out SUPER ! I am very pleased with it. Kevin kept me well posted on progress GREAT person to deal with !
Monster Mike
Actually the alt & oil pressure gauges are just lights on the 64 F100 cluster so it would require cutting larger holes to fit actual gauges in.
Ill just use that one while I'm getting my bronco one refurbished
fallingdown
fallingdown
I can add mechanical gauges, not a problem. The cluster housing from the F150 will require some modification but it is relatively minimal. The valuable part of that cluster is the speedo head unit. It is always a good Idea to send multiple clusters if you have them so that it can be cannibalized to make one good cluster if needed.
