Finally! - Finished my front bumper - Build pics added
cbearly
cbearly
Wellington, Colorado
Build Description & Pics
With the front plate cut and the ends built, I clamped them in place and tack welded it all together. I also cut two triangle braces (one for each side) for additional support from the inserts to the end pieces. I tack welded one to each insert just in front of where the insert meets the frame, and to the bottom of each end piece. They run parallel to the ends of the front plate about 3” behind. I then cut and tack welded the 45 degree pieces below the shackle mounts on each side of the center section. After I had all this tack welded I went back and filled in all the welds moving around a lot so that I wouldn’t warp any of it. I welded all the parts on both the front and back sides. After filling in all the welds, I cut and welded in the triangle pieces under the end tapers on the front plate.
cbearly
cbearly
After everything was welded together, I ground down the welds on the front of the bumper, and used flapper disks to smooth it all down before painting. After grinding the first time, I did have some low spots that I had to fill in with the welder and grind down again. After grinding and smoothing everything out I primed it and painted it “trim black”. The winch fits in tight enough that I have to slide the bumper in part way, then bolt the winch in an slide the bumper in the rest of the way. It’s also pretty tight getting the horizontal bolts in – just enough room on each side of the winch to get a wrench in there.
trailpsycho
You definitely raised the bar, cbearly. Fantastic job. Lots of great ideas. Do you have plans for a rear as well?
Benzo
SF Bay Area
I say find a fabricator, share your specs, have them build them and get some proceeds from the design :) I know I would buy one!!!
