BroncoMarc
After having EFI issues for well over a year, I think I finally found the problem.
Previous posts:
http://classicbroncos.com/forums/showthread.php?t=122956
http://classicbroncos.com/forums/showthread.php?t=129691
Getting ready for a trail ride on Friday it was running rough, so I replaced the HP fuel pump AGAIN. Pressure was still low, so I ran an extended line on my fuel pressure gauge so I could see it while driving. I noticed that just before cranking I had 40 PSI, but it immediately dropped to 30.
I started playing with things and found that when I unplugged the vacuum line from the regulator that the pressure went up to 40! I ended up leaving it disconnected and I had the best 3 days of wheeling I've had in a long time! No EFI issues!
The pressure did gradually rise during the day. When it got up to 55 I put the vacuum line back on for a second and reset it back down to 40.
So... Since I replaced the regulator 6 months ago, I'm guessing I've got it plugged in the wrong place. Where should I plug this into a 97 Explorer upper manifold?
This is where I had it plugged in. I had the C4 T-ed in to it:
Previous posts:
