needabronco
I recently finished my efi swap, and everything was running great. I put around a 100 miles or so on it around town to make sure there were no issues. Last week I headed up to Colorado to camp and experienced what I can only describe as 'vapor lock' issues, each time it happened I was above 10,000' and was in 4 Low, idling in first gear. What was happening seemed like fuel was boiling in the fuel line and fuel rail and overheating the fuel pumps. It happened a total of 3 times the last which was the worst was at 13,000'. My engine is in excellant condition and never runs hotter than 190*, even in 110 degree heat. Now my engine will run for about 5 minutes then it dies, after the accumulator runs out of fuel. Both pumps turn on but feel week, how can I check my pumps idividually to determine what the problem is? I think the low pressure pump is week and doesn't keep up with the high pressure pump(?).
My fuel system consists of a low pressure pump that feeds an accumulator then to the high pressure pump. My fuel lines are routed at least 12-18"s from the exhaust and the lines are routed up to just under the master cylinder, from there, there is about 8"s of high pressure line to the fuel rail. Both pumps were new from BCB, and are mounted on the frame rail between the tanks.
Anyone experience this and have a good permanent fix?
Casey
Casey
