gunnibronco
I'm going to pull a 96 Explorer motor this weekend. Its got 88,000 miles, and I'm getting it serpentine to headers.
To start, if you have any tips or suggestions for getting it out quickly, fire away. I planned on buying a new harness, is there any point in taking the Explorer harness? Should I just cut it off somewhere since I'm not using the Explorer ECU? Is there any ignition parts I should grab? or is the distributor enough?
I don't have salvage yards close by, so I want to pick up everything possible. It looks like this yard has some Mustang parts.
Should I pick up a new or used Mustang MAF sensor? Is this a service part that may be bad? What should I look for to spot a bad one. I'm sure I won't have this running before the yard's 30 day warranty expires.
I've read that buying the Mustang computer new is better than buying used. Correct? Is this something Napa or Carquest caries?
This Explorer motor is on an auto tranny. I'll install it on my NP435, so I need a flywheel. This yard has a 95 Mustang flywheel for $50.00. Is this the correct flywheel? What do they cost new? Where to get them?
Finally, I've built a York compressor bracket, sitting horizontal, above the my current alternator. I also JUST bought a 200 amp big body alternator from RRAAAYY2. I'd like to use it, and the on board air. Any thoughts? Since I live in the sticks, I've never got a chance to check out what an Explorer serp looks like. Any pics?
Chad
Chad
