I'm sure this is an easy fix, but I can seem to figure it out.
77, all stock 302, automatic. When coming up to a stop, nearly every time it will stall. Turn the key, starts right up. Only happens when it is warm, on regular idle (not high idle). Took it through a graduation parade and had to keep it in "N" every time we stopped to keep it from dying.
Anybody have any thoughts at what to check first?
I've adjusted the idle speed, doesn't seem to do anything. Started doing this out of the blue after sitting for 2 months or so. (ethanol gas). Sprayed carb with cleaner. No help.
Wondering if the fuel pump is weak.
