I thought you just did? Although I can’t say I know anything about the harbor freight alternator tester, even your voltage shows that the alternator is working.
If it’s putting out 14 1/2 volts, it’s doing what it supposed to do.
But as far as testing the diodes so that they are not allowing the battery to drain, I’m not sure how that is performed. Although, generally speaking, most auto parts stores can bench test an alternator.
At least the bigger chain stores when their machines are working and the employees know how to operate it.
Then, again, and easy test as to the next time, you park the battery vehicle with the battery, fully charged, disconnect, the battery, and let it sit for a few days. If the battery goes dead, while it’s disconnected, the battery is bad.
Another thing you can check is the regulator.
If you disconnect the regulator and the drain goes away, you have a bad regulator.
But with your multimeter, you can test the voltages on two of the wires at the regulator.
The yellow wire should have power whether the key is on or off.
The green with red stripe wire should have power only when the key is turned to the on position.
The orange wire shouldn’t have anything on it.
If you have power on the green with red wire while the key is off, you have an ignition switch or wiring problem.
