rekoj71
- Apr 18, 2009
- 361
looking for opinions/experiencies with different dual battery installations/kits
I'm looking into dual battery kits on the web and there seem to be 2 different approaches to the idea.
1) uses an issolator ( http://www.warn.com/truck/accessories/battery_isolator.shtml ) that isolates the batteries all of the time, thus keeping a battery for starting and a battery running all of the accessories, so that if you drain your battery while the engine is off, the starting battery will still be charged and get your engine started again.
2) uses a solenoid ( http://www.painlessperformance.com/webcatalog/largeview.php?SearchField=40103 ) that disconnects the second battery when the key is not in run or start, and keeps the second battery in reserve to help jumpstart the main battery if it would become drained while the engine is off. All of the accessories are to be connected to the main battery in this set up.
There might be other ideas or options out there and I am looking for opinions and experiences with how well either system works or any charging issues to be had with them.
I am toying with running 2 optima yellow tops which that company says can be used for both starting and deep cycle applications on there web site, but would like to know what the best way to control/charge them would be
