- Nov 11, 2007
- 7,840
I have the painless harness, very nice, but I'm at the point I need to decide to use the already installed painless blade connectors, or go through the hassle of rewiring each and every plug under the dash with stock connectors.
First, OEM connectors for things like headlight switch are made to make manufacturing easy. Made to make the offhand chance of replacement easier., But mainly support a plug and play assembly line. Can you imagine a guy on an assembly line plugging each blade on each switch of each truck? Nope.
Now, I'm sitting here thinking the replacement painless harness already has very nicely crimped and sealed blade connectors which will hold as well as the OEM plug, and save me a ton of time. Downside is if there is a time later it may take a few more minutes, just a few, to swap out a headlights switch.
So what to do, breakout each and every plug, or use the painless answer right now? I'm trending to rewire the plugs for looks. But it is under the dash and only I will know, which is the problem.
