I just went back and re-read the description of that housing - I didn't realize it was 1" wider than stock. I thought Currie used to have a low-pinion version too but they don't - Tom's does though with similar construction which makes me wonder if Tom's got an exclusive for the low-pinion version.
And fun fact from the history guy - the Bronco's D30 was the first open-knuckle axle used on a domestic 4x4. Ford did extensive testing with it at the AZ Proving Grounds prior to the Bronco's introduction to make sure that its lack of seals would work ok. Obviously - 58 years later, they were right.
Todd Z.
I don't think it actually is wider. I hope that we can ask
@NorCalBronco to measure the distance between ball joints on the bare housing, and compare that to an original D44. (image coming soon...)
I think that Currie is using the same incorrect reference dimension from the Early Bronco literature. Their website says that their housing is 60 inches WMS. That is the same as Early Bronco disc brake 44.
The axle that Currie is peddling is basically a Jeep JK Rubicon high pinion center with the link mount deleted. With the thick wall 3 inch tubes, It vastly superior to anything ever put into any Bronco. (including 6G) I really like it.
Be aware that there were three kinds of Dana 44 tubes that came in a Jeep JK. Bent ones, soon to be bent ones, and never driven ones.
@NorCalBronco you will want to get a comprehensive BOM for your axle from Currie. They are REALLY bad at "remembering" what they built. In about 10 years, every component on your axle will be obsolete, and no one at Currie will tell you (or know...) what you've got. But if you can get a master list, you will really appreciate it if you ever have to service it. I'm pretty sure that they used 2007-2018 JK Rubicon ring and pinion. But I don't know which carrier, which spline count, and which bearings. Also want to know the dimensions of the inner stubs. A drawing would be acceptable, but knowing the application would be even better. I often get 10-20 year old custom axles in for repair, and have no clue what was built. Dynatrac and Currie are the worst, but TeraFlex is trying hard to catch up. Solid Axle is remarkably "solid." I've given up on the 9 inch stuff, and I'll only order parts AFTER I confirm.
The only thing worse than having a custom axle manufacturer unable to answer a question is to be unwilling to answer. You can imagine the conversation...
ME: "Hello, I am working on a Bronco Axle that I didn't buy, that I have no receipt for, that has no serial number, but it has a really pretty Logo welded on it. Do you have the inner axle seal part number?"
THEM: "No. Are you going to spend $4900 today? Go away."
