Have a new build with a bug I am trying to get figured out. New GM disc brake kit up from from WH, Explorer disc brakes in the back. Hydro boost kit from WH as well. WH proportioning valve. When I press the brake pedal, the brake light comes on. I didn't have a pin in the proportioning valve to keep it centered when I bled the system originally. Other than a moderate left pull when panic braking the pedal is firm and the truck brakes well and feels balanced between front/back brakes. I have tried bleeding all brakes again, hard braking, press and hold to let the valve settle and re-center and can't seem to get it back to center. I have not found any leaks or anything that would cause it to activate. Thoughts?
