So I am finally getting back on my Bronco after taking some time off for the family. I am in the process of wrapping up a 351 install and hitting the home stretch.
Here is my dilemma. I went to connect the battery and the positive cable/post connection starts sparking and smoking on me so I have something crossed some where.
Here is how I have it hooked up: Negative post on battery to ground on engine block and the same bolt also has a ground strap from the block to the frame.
Positive post on battery to starter solenoid post on left side if you are looking at it straight on. Right side post on starter solenoid to starter. I also have a 3g set up that goes from the post on the 3g alternator to the left side post on the starter solenoid.
Here is what I know. If you disconnect the starter from the solenoid and leave the 3g alternator hooked up and hook the battery up no sparks and all is good. If you leave the starter hooked up to the solenoid and disconnect the 3g alternator it sparks/shorts out when you hook the battery up.
So what that tells me is my issue is from the solenoid to the starter is that a correct assumption? Also the solenoid is brand new and the cable from the solenoid and starter are used.
So is my solenoid bad or is the starter grounding out somewhere?
