My current set up is a 97 Explore 5.0 swap . It’s been reliable and runs great. But I can tell it’s getting tired and needs to be rebuilt. It’s not smoking or over heating but it has probably pushing 250k miles on it. I can tell it’s loosing it’s punch. So I’m kicking around what I want to do. I’m currently using all the stock Ford stuff I can. In the tank Fuel pump, power steering pump, EFI Aluminum radiator, Explore front dress , Explore EFI , GT40P heads, AX15
My options ...
1-Of course the easiest route would be rebuilt what I have. Bore it , upgrade cam , I have a set GT40X aluminum heads that need to be worked.
2-347 stocker Build the heads, select a cam. I would need to get it tuned. exhaust, front dress fuel delivery would stay the same . Cost goes up quick , stroker Kit , machine shop,
3-351W. We all have heard “No replacement for displacement” . Stock block, select cam . I definitely want to keep my Ford EFI stuff. Either after market lower intake or use an adapter to use my upper intake. Could I use my front dress? Is the fuel pump big enough? Will my radiator be up to the task? I would need to get a ECM and tuned.
Looking to hear from guys who been there and done that .
My options ...
