I'm about to pull my 66 column out for a power steering install. Any thoughts or pointers you'd be willing to share? Best of luck finding that boot.
Beauty. Thanks for that insight man. Do u need to yank the box first to get it out or can u move it over enough to slide it pit with the box still in? I appreciate you.No need to remove the column. Just loosen it at the firewall and under the dash, then slide the one piece steering shaft out the bottom to the inside of the frame rail. Reinstall whatever steering shaft you'll be using with the PS box before you tighten the column back up and before you install the steering box.
They're both coming out. Just wasn't sure if one should come out before the other.If you're removing the manual box to install PS why wouldn't you just remove it to begin with?
Hey bud. Hate to resurrect this again. Did you remove the blinker assembly in order to pull the shaft out on your 66 or were you able to slide it out without depinning and pulling the wires out? I have the steering wheel off and it looks like there's a snap ring on the top of the shaft that would be easier to get out by removing the blinker wiring and my fingers are crossed that I may not have to. Thanks again.No need to remove the column. Just loosen it at the firewall and under the dash, then slide the one piece steering shaft out the bottom to the inside of the frame rail. Reinstall whatever steering shaft you'll be using with the PS box before you tighten the column back up and before you install the steering box.
I didn't even think about that because mine doesn't use one. The snap ring should be on top of the bearing.What about just removing the snap ring?
I'd have to pry and pick down below the collar for the directional and risk damaging it. If what i saw was indeed a snap ring, it is recessed down a bit. I'll shoot a pic when I'm in front of it.What about just removing the snap ring?
It’s probably a simple as loosening the lower, retaining collar, if you have one, and once the shaft is disconnected from the gearbox, you slide the shaft up towards the driver.I'd have to pry and pick down below the collar for the directional and risk damaging it. If what i saw was indeed a snap ring, it is recessed down a bit. I'll shoot a pic when I'm in front of it.
Ahhhhh. Didn't think of that as an option. Will try this tomorrow. Thanks guys.It’s probably a simple as loosening the lower, retaining collar, if you have one, and once the shaft is disconnected from the gearbox, you slide the shaft up towards the driver.
That gives you plenty of access to the snap ring. That’s my recollection anyway.
There's def some kind of ring. Should be fine. Looks easier than I had originally thought.
