I just got my bronco a couple weeks ago. I just replaced the intake manifold gasket and the valve cover gaskets. I replaced a couple fuel lines around the engine because the were extremely clogged up... It has very nasty gas... Draining tank is the next step. After doing all this though I got the timing on the engine halfway right but don't like to run it long because my oil pressure gauge now stays at zero. Engine isn't running great yet since it needs some more tuning... But wanted ideas on what could cause zero oil pressure (or I guess maybe the oil pressure gauge broke when I had the covers pulled off.)
Let me know!
Grantoser,
Congrats on your new purchase! The others have given you a lot of good advice / things to look for and I agree with checking all of that... I would also mention that since you had the intake & valve covers off, I assume you probably disconnected the wire harness at the firewall at the rear of the driver side valve cover - if yes, that wire harness contains your oil sending unit wire and temperature gauge sending unit wire. If the connector isn't fully engaged or maybe a broken wire or something of that nature, could cause a problem. Does the water temperature gauge work OK?
You mentioned that you had a clear tube running to your gauge which indicates the PO (or someone) installed an aftermarket "mechanical" oil pressure gauge. Did the factory gauge (in the factory cluster) work also or just the mechanical gauge? If the Bronco only has the mechanical gauge, then it probably doesn't have the oil sending unit and the wiring suggestion I mentioned previously becomes a moot point.
I run 2 oil pressure and 2 water temperature gauges on my Bronco - I added a "T" fitting at the oil extension tube and two sending units (one factory & one aftermarket). I originally installed a mechanical gauge as the second location but it started leaking oil all over my brand new carpet, so I replaced it with an AutoMeter electric oil pressure gauge.
Good luck on finding the issue and keep us posted.
DJs74
