A pinkish wire coming from my ignition switch and runs thru the firewall into engine compartment, and then who knows where, is getting warm when ignition key is turned to ON either when engine is running or not running. The wire appears to be original to the wire loom as it was wrapped with other wires. Also it has an extra wrap on it when bundled with other wires.
I have a 1969 bronco with a 302 that did not come with the bronco. It also has the electronic ignition box as the 1975 model bronco came with standard.
So, what is wrong and how can if fix it?
