Wild horses Delphi pump question
Kyle.malone
Norman, OK
I am tinkering around with the idea of switching over to hydroboost brakes. I have the Wildhorses HD Delphi Saginaw pump. It does have a green painted threaded bolt with a nut on it and was wondering if this was a pre tapped high pressure line or something else. I know I can "T" the return line without a problem, but trying to figure out the high pressure side for the brakes. Here's a ;ink to the pump.
http://www.wildhorses4x4.com/product/HD_Delphi_Pump_w_Vbelt_Pulley/Bronco_HD_Delphi_Steering_Pumps
I am also going to eventually go to a ram assist steeriing. Can this pump support all three units?
DuctTape
Bozeman, MT
Isn't threaded high pressure and push on low pressure? Call wild horses would be my suggestion, every time I have called with a stupid question they have been great.
WILDHORSES
USA
Hi Kyle, the green bolt just holds the can to the pump. There is only one hi pressure port in the pump. As for the return using a T is the easy way and works 98% of the time. Run it like this.
-----return from steering box----T----to pump
Run the return from the box straight through the top of the T with the hydro coming in from the bottom. Hope that makes is clear.
The pump should be able to power all you want to do RAM, P/S, and hydro.
Have fun!
Kyle.malone
Kyle.malone
Norman, OK
Have fun!
Thanks for the reply! Looks like hydroboost is in my near future especially with the atlas coming in the next couple of weeks (thanks again for getting that ordered for me too)
