Berky
- Jun 11, 2015
- 88
Im looking for help on how / where to place shims to fix my issues.
Long back story so i will try to make it quick. I replaced the door post, inner, and outer rocker. Everything was square and the door fit in the opening with decent gaps. Later on I replaced the body mounts with WH +1" and the alignments went haywire.
Current situation is it appears the entire front half of the driver side needs to rotate up a lot. The back of the door sticks up 3/8" from the quarter. I originally shimmed the top hinge and that fixed the problem, but I had a huge gap at the windshield frame so i pulled them out. I already have about 1/2" of shims on the rear driver quarter. Without those the gap is twice as bad as it is now.
Also, the grill is 1/2" lower on the driver side. If i just add shims at the grill mount it binds the fender at the rocker panel. I was thinking to start with several shims at the front and half as many at the driver floor pan, but I wanted suggestions from experienced people first.
Where would you start placing shims to correct this?
