Where to find low cost reliable C4 Rebuild in D/FW area
Bilgamesh
Pilot Point, TX
Can anyone recommend a low cost and reliable C4 rebuilder in the Dallas, Denton or Fort Worth area? Mine is about ready, and I got a quote today of $1100. That seems way high as I have read on here of people getting them done for $450. Please advise. - Thanks
t.lay
Grayslake, IL
I suspect mine is nearing the end of its days too.
What about a TCI or similar tranny??? - they seem reasonable in the Summit catalog - you'll already have the correct adapter and bellhousing... Fresh C4 for about $600 or $700 (assuming you use your old torque converter). This version says it can handle up to 300hp. For another $200 there's a 450hp version
Seems like you'd want to avoid the retail tranny shops if you want a budget build.
NicksTrix
are you taking the trans in to them or are they pulling it. that has alot to do with the price.
79driver
For what its worth i got a C6 done here in stephenville for $600 they pulled it and reistalled too. Go by the shops in your area and take a look, ask them a bunch of questions ect. You should be able to pick out the good ones from the bad.
PsYcHoBrOnCo
Fort Worth, Tx
x2, on searching out a good shop....now days a decently priced reputable shop is hard to come by. Here is a contact of local shop we have done business with at my work. Mind you, I have never had any personal work done by this trans shop but thru the years we have used them for small job's and had sucess. Good luck.
Moses Trans 817-332-6415
Baja71
I'm in the same boat as you. In researching a C4 build, I called Eagle and they wanted $900-1100. I'm not quite sure about their rep. though. I called the Transmission Shop in Plano and they wanted $475-725 depending on any upgrades, with a 6 mo. warranty. I called Broader Performance in Weatherford and they wanted around $500?? or so with a 12mo. warranty. He seemed to know about the EBs and was willing to chat on the phone about my needs.
Bilgamesh
Bilgamesh
Pilot Point, TX
Ed's in Arlington just quoted $870 to remove and install, w/24 mo. 24,000 mi warranty. That still seems a little high, but they were recommended by another EB owner. Still shopping!
Bilgamesh
Bilgamesh
Pilot Point, TX
Does anyone know what the difference is between a basic rebuild as opposed to a full rebuild, and what the criteria are for the latter. I am a little leary of driving in for a basic rebuild and walking out with a much larger price tag. I would appreciate any experience or expertise. - Thanks
