I’ve been working on installing the WH 3 way adjustable tie rod and drag link system. So far everything has gone well until the last step of installing the drag link to the stock early ‘66 manual steering pitman arm.
Issue: The ball joint stud on the new WH drag link that goes in to the pitman arm is a larger diameter than the original. My assumption is that the early ‘66s have a smaller hole than other years?
Any recommendations on best option to take here here?
1) Get a new pitman arm? Would 1967 work?
2) Ream the hole on the original early ‘66 pitman arm to accept the new larger ball joint supplied with the WH drag link? (I have no experience doing this)
3) Install a new ball joint to the end of the new drag link that fits the original pitman arm hole? If so, does anyone know specs on which one to order?
Thanks guys!!
Thanks guys!!
