    Discuss it more here:
GA WANTED: 68 Bronco Drum Brake Proportioning Valve
Status
Not open for further replies.
68bronco1x
Need a good used original drum brake proportioning valve for 68 Bronco.
Ford part C8TZ-2B257-N stamped valve body.
thegreatjustino
Red Head Grease Monkey
Stockton, CA
How are you defining proportioning valve? A '68 Bronco only came with drum brakes, so there was no proportioning valve.
Are you looking for the brake imbalance light switch? Also known as an H-block.
68bronco1x
Maybe I am calling it the wrong thing. The Ford parts manual calls it the Brake Pressure Differential Valve. It works the brake warning light switch. Mounts on the drivers side frame just under upper front brake bracket. It is probably what is called the H block as it sort of looks like an H.
TheBroncoRanch
I have a few of themhere PM me
[/URL][/IMG]
68bronco1x
The valve I have was stuck and would not allow the warning brake indicator to work. Last nite I took it apart and got it to work. I am going to try it out for a while and see what happens. I will get back with you if it doesn't work.
Thanks again
TheBroncoRanch
Thanks again
Cool, hope it works out. Fixing it is always better than buying it 👍
Status
