Pechin0351
- Jun 30, 2010
- 82
I may just be losing my dang mind, or I was drinking when I started plumbing this vintage air system. But can someone just help double check my work and maybe give insight as to when the electronic heater valve should move.
I have the pipe coming out of my lower intake manifold (with coolant temp sense) that goes to the firewall, into the electric valve, and into the heater core. Then back out of the heater core, and piped to the lower of the two ports on my water pump. The electric valve has the little arrow pointing towards the heater core if anyone was going to bring it up.
I marked the valve with a sharpie to see if it rotates but my mark never moves. The lines also don't feel like they are getting too hot, but I can burn the shit out of myself on my upper radiator hose... so there is hot liquid moving around.
Conclusion A: I have lost my shit and need to just wait
Conclusion 2: I muddled something up pretty fierce
Conclusion biscuit: I need more beer
I have tried moving my controls between all four vent settings, I have adjusted fan to all speeds, and I have tried rotating my "heat knob" in each direction. Never do see that white plastic rotate on the heater valve.
