285 is a tough tough tire to clear. 100% not worth the effort. I had them, you need 17x8-4.5" then you need to narrow your axle 1.5 or so total inches. Then shock mounts have to be moved, 275.70-17 is much better. I actually love my new stance.
265/70-17
Bronco Brian, What wheels did you use for the 4.5 BS?
I plan on running BFG tires, here is my bronco with the 33x10.5 15" wheel and 285 with 17" wheel.
Rear is cut with metal fender flares shown with 33X10.50-15
904 Bronco-are these 285-75 R17 your running? The stance looks great..planning to do the same.You will lose some turning radius with factory arms in front and will need to trim the front fenders some. But since mine was already cut when I got it, there wasn't an issue.
Method wheels from 4WParts wholesalers
2.5" lift from WH's in front, 3.5 WH's leafs in back
