DanWheeler
I need to re-do the brake lines from the master cylinder down to the front/rear tee on the frame. Do I absolutely need a rubber line between the master cylinder and that tee? there is one in place now but I'm thinking it will make things more difficult to keep it there rather than just bending new tube and going directly to the tee.
If I DO need rubber hose in between there where can I get some that will connect to the pre-fab hard lines I buy at NAPA? I guess rubber lines would be nice in case I add a hydroboost at some point in the future.
thanks,
dan
BTW - there is an electrical plug going into the front/rear splitter on the frame - what is this for? is there a dummy light for brake pressure?
thanks,
dan
