Well, with just 1/8" per side difference, you would think that it wouldn't make much difference. But it can...
Double check with them of course, but I would have to say that, while they'll work fine on one Bronco, they may cause some head-scratching on another. You know how that goes. And the oft-used phrase, "your results may vary" can come into play.
However, if it gives you a little trouble by creating an angle on the u-bolts, in most cases it would probably be a simple matter of drilling/filing out the holes in the clamp plate just slightly to the outside.
You don't want to simply enlarge the holes though. You want to open them up outward, which is where the u-bolts would naturally want to sit when laying on the edge of the slightly wider perches.
Probably not a big deal to most, but worth mentioning.
In fact, if there's enough meat on the plate to make the holes just slightly larger still, now would be the perfect time to upgrade to some 9/16" bolts.
Of course, you could go bigger still and use 5/8" stuff like our Extreme kit, and probably some stuff that Ruff Stuff sells as well most likely, but I'm thinking that the top clamp plates really are not up to that large of a bolt.
You certainly would not be able to torque them to full bolt-spec as the stock plate would just bend under the pressure. But I'm even wondering if there's enough material to work with anyway.
