- Jul 31, 2001
- 8,800
Excellent info Paul (as always)
Disadvantage of the Set 20 brgs is the axle seal can only be replaced if the brg is pressed off the axle itself. Usually this results in messing up the brg so you get to buy new brgs, new seals and then if you don't have a press pay to have them pressed on.
With the stock brg setup for an EB the seal fits into the housing and then you install the axle into the housing. So you can replace either w/o being forced to replace the other.
Both of these have a common safety disadvantage-
Besides the obvious "beef and toughness" (huge R & P, and axle housings that don't bend) advantage of the 14 bolt is the huge SAFTEY issue of the FF design of the 14 bolt. The axle on the 14 bolt does not rely on a simple "tension fit" pressed on bearing to hold the axle in place. When a stock drum brake 9" axle bearing fails on an EB the axle either breaks where the brg mounts due to heat build up or more commonly the bearing heats up due to the housing being bent and the axle can then "walk out" of the housing and your tire/wheel and axle pass you by as your driving along on your bumper or leaf spring bolts. So common it's spooky. We used to buy EB's that were towed to town off I90 often rolled because the rear axle came out due to simple brg failure. My buddy bought 4, all rear axle failures.
The 14 bolt FF axle prevents all that. I had it happen so many times I won't run a 9" axle in a 4x4 environment unless it's a FF. The housings are too lightweight w/o trussing to prevent bending and then ultimately having your tire come out beyond your fender.
Edit: Schreiner Enterprises still sells FF kits for 9" housings relatively cheaply.
