broncomitch
so...i hooked everything back up onto the 351w. for the ignition i just plugged in the distributer and checked my conections....
and tryed to fire it up...it had a hard time turning over and no spark... and the lights where really dim....well i forgot to hook up the ground wire from the batt to the motor.
so hook that up and everything works grate but still no spark.???
I had a blown fuse from the hot wire to my box, so replaced it and tryed to crank it and it popped again...so double check everything and try again...it would turn over but when i stop turning it over it will pop again....well after fighting a fuel problem for almost 2 hours i got it to fire up...it would run for maybe 5-7 seconds then the fuse would pop again???? went through 12 fues's 15's and 20's
i checked out my box and the main ground wire is melted...but its not hot???
i don't get it, everything worked perfectly with the 302...but put the 351 in and i have alllllll cinds of grief!
oh and my exhaust wont bolt up to the 351 ether!
and my transmission is not working as well...i put it in gear and it feels like it go's into gear but i hit the gas and nothing...??????????
