Hey guys. I finally got my wiring on my eb finished and well I have quite a few problems I need help with as I'm am not good with this sort of thing to begin with. In the last year I have really buckled down to get her on the rd and this has really taken the wind out of my sails. To the point I dunno if ill ever get to enjoy it.
Anyways enough crying. A lil backstory. I just put a painless harness in my 72 and a ronfrancis efi harness on my 393. Both came from wild horses in case yall are wondering the exact model of harnesses.
Both are not working correctly. I don't think the issues are connected but they might be.
First . The battery is old. I didn't want to buy a new one and watch it go bad while the eb never left the shop so I have a charger on it when I'm testing everything. When its right ill buy a good battery.
1. Wiper motor. Ran on low but blew the fuse when I went to high the first time I tried it. After that it blew as soon as I switched it on . With motor unplugged fuse is fine. Is this indicative of a bad motor or something else? How can I test motor?
2. Fuel level reads e on both tanks. I know they both have 5 gallons in each of them. at rest the needle is below E when switched on it rises to E then stops. Would this be senders? Coincidental that its the same on both tanks. How can I troubleshoot this?
3. Maybe worst issue. Blinkers work fine with lights off. Lights on and the front left indicator light comes on and blinks slowly. The actual bulb doesn't burn at all. I've checked grounds and connections they seem good. I've swapped side markers and blinkers and yhe problem moves accordingly so I don't think there is a problem with the lights themselves. Im leaning toward something in the column but don't know where to start with troubleshooting.
4. Maybe separate altogether but I cant get the motor started either. It will crank fine but not start. I have spark at the plug. I've checked to make sure I wasn't 180 out and I've moved the dizzy all over with out so much as a cough. I tried a noid light on the injector harness and it flickered but I'm not too sure the injectors are firing . Swapped plugs and they looked dry. 38 pounds of constant pressure on the rail.
5. I dunno i if its the charger or something else but when the ignition is on the alternator and the efi relays start heating up. That doesn't seem right to me but I don't know what to look for.
I dunno if any of these issues are related. And I don't know which direction to turn. I have worked so hard to get to this grand finally and poof. I feel like Clark Griswold with his house lights in Christmas vacation. This sux.
Kevin
Kevin
