deltabronco
- Dec 27, 2005
- 1,100
So this is the 4th time, and 2nd torque converter , that I have bolted up to my new BP 306. Each time the engine will warm up and a noise will continue to get louder from the bell housing area. I checked the bolts and internals around the tC and nothing is scraping. I initially thought it was the TC but ruled that out when I put a new Hughes in. It’s been a pain getting the TC, flexplate and c4 all to fit. I even had the transmission rebuilt while it was out. Aside from the noise the vehicle idles good but runs with very little power when put in gear ( almost like the it’s running on 7 cylinders.
I decided to break down and buy a complete C4 with torque converter and flexplate from Kurt Strecker. Just making sure when I do the install I’m not missing anything. Bolt everything up, make sure engine is not binding and can be rotated by hand. Put 4 qts or ATF-F in. Crank, run then add 2 more quarts, shift through gears. Top of fluid.
Anything anyone may want to add?
