Unhooked purple wire to solenoid. (Is red in pic because original wire wasn’t long enough) once disconnected it would not turnover.
Naturally. Just what would be expected.
Purple wire is what energizes the starter.
Normally has nothing to do with the ignition system, but in this case I see you are using a PMGR/mini starter. Does the lack of a picture mean that you no longer have a Ford starter relay on the fender?
To make sure we’re all on the same page here, is your ignition switch connected directly to the starter solenoid on the starter?
No more starter relay on the fender?
Positive battery cable runs straight down to the starter?
And even though this is unrelated, or should be, is it just the angle of the picture, or is your starter cable awful close to the header tube?
I don’t see any signs of melting or burning, but it sure looks close!
Didn’t touch key or anything and tested voltage to coil. 12 bolts were running to coil with key in run position.
Well, that’s both good and bad.
Good because it supposed to be there, bad because it would’ve been nice to find something obvious.
I wonder if the coil is overheating?
It shouldn’t, because that type of coil is usually made for 12 V. But you never know.
Next time you fire it up, have a jug of cold water handy and when it dies, cool the coil down with the water.
Or, when it gets close to the five minute mark, just start cooling the coil down anyway to see if it idles longer.
What are the three wires going to the coil?
Specifically the orange wire?
