I have a hydroboost unit that im 99% sure is the f250 unit. Looks the same and has same numbers on it so it has to be it. Now since im throwing a ppump cummins 4BT in I can not fit the unit straight to the firewall I have to use either the angled bracket or that other one on ebay that mounts it further over parallel with the fender but I will be installing a clutch master on the firewall in that same area and this parallel bracket I think some have said will block this area. Both of these brackets are advertised for use with astroboost not f250. Do you think mine could bolt up. Id rather buy somrhing that will work rather than have to customize shafts etc. Or should I just sell my f250 hydro and buy an astroboost. One less headace for me is worth it. What do you guys think?? Thanks for any input
