66 Bronco with a floor shifter and dash mounted hazard switch. Did a complete re-wire with the American Autowire harness. Only wires going to the steering wheel are turn signal and horn. After much hair pulling I got the electrical completely working. Except for the hazards which only work when the turn signal lever is engaged left or right. The lights flash as they should, left and right turn signal and hazards. Yet the hazards will not flash when hazard switch is pulled out and the lever is in “neutral”. I also have a pair of LED turn signal mirrors but the problem persists even when I disconnect them. Any thoughts?
