Front grill
TheBiologist
I am putting my Bronco back together and was wondering how far off the frame does the grill sit? I ask because I have a suspicion of front frame damage......
Jamie Chriss
If you want some really good advice post a picture. Sign up to be a contributor, there is a small fee but it will pay for itself after one post.. Good luck
T
TheBiologist
Wow not the reply I expected from the forum I was a contributor on in the past. Why would I need to post a picture to get somebodies measurements?
Pops68
Bronco Rookie
Bazetta Township
Possibly to see what you are actually dealing with......pictures do help these guys analyze things. They are GOOD!!
Do you mean how high - How much of a gap between the frame and bottom of radiator?? Stock radiator?? V8 or V6??
Bronco Junkie
So Cal Broncos
I am at work right now so I can't measure for you but there are 2 frame rails that the stock bumper bolts to. Is your grill equal distance from both of those frame rails?
Pa PITT
Stephenville TEXAS
Pictures were the 1st thing I thought of also. I wasn't totally sure about your question.
... But I think after my lift 2.5 inch & Now I think there is about 3 plus inches between .
MarsChariot
Planetary Offroader
Albuquerque, New Mexico
As a rule of...forefinger, if you can't get your forefinger between the grill and the frame it is too close. A fat forefinger and stock clearances, maybe not then either. Could be body mount damage too. It is so close in factory configuration that a 1 inch body lift actually looks normal. Also, frame damage is rarely even, so if one side is closer, then something is not correct.
