T-7ToNewOldB
- Dec 7, 2018
- 315
All new build.
Dana 44 from TBPs, 4.09:1
Ford 9” Rear from Wild Horses 4.11:1
(Both WHs and TBPs were ok with this difference)
Atlas 2 speed
1” Body Lift
1.5” suspension lift
7degree bushings
So have only put about 500 miles on the truck. Rear wheel only, though I had done a quick test of the front.
A little snow here today so put her in 4wd. Could feel a bit of vibration at any speed. Didn’t seem to change a ton with RPM or speed.
Most pronounced during engine braking. Doesn’t go away with clutch it.
Goes away if I put front back to neutral.
Goes away if hubs are disengaged even with Atlas in gear.
Definitely shouldn’t be there.
Haven’t run in just front wheel drive, will try that shortly. That would eliminate the interaction with the front and rear ratios or something else.
Thoughts? Questions?
Atlas 2 speed
1” Body Lift
7degree bushings
