Progres!!
Well, I found what was "wrong" with the way the radiator was sitting... When this thing has been crashed at some point they never did proper repairs like you can see on this front corner.
The bottom radiator hangers were crap welded in place and were crooked, then I found the body mount/core supports were completely busted. I unbolted this one and it fell out... You can see how far it had been bent as well.
So I cut the core support, the mounts, and the passenger fender apron out.
I guess it is important at this point to note... I am not a welder. I have never touched one in fact (well, to use myself) But I got one, and tried using it... It was that gassless self shielding thing... I could do some welding alright (messing around on old parts) but others it would jut burn through. I borrowed a better mig welder, and he set it up for me so I went to work. I did ok, better in fact than the work that was on the EB.
Here is the core support to driver's apron, and core support to drivers body mount.
Not related (or mine).. but about this time in the project I drove by this.
...back to my rig ;D
Then I tossed a coat of primer on it.. (and another pic of my welding on passenger mounts/battery tray)
Then taped off the engine and bumper and sprayed some satin black on. I tried to get everywhere I could in the engine (front of passenger wheel well and front/top of driver's) I think it made it a bit nicer in there =)
So on the way back together... this plug was nice enough to rust in my radiator
I tried to use an extractor to get it out, but didn't know the hole was so shallow and managed to crack the thin membrane that keeps the fluids from mixing... so had to pick up a new radiator. %)
Unmasked and going back together
I moved the top radiator brackets to the front side of the core to get a little more fan/radiator clearance *and uh... flipped the fan over
While the front clip was off, I figured I would try to rattle can it a bit closer than it was (dull primer) I thought I had found it.. but I didn't.. opps!
So I took it down with the hood to have a quickie paint match thrown on it... While that was down, I figured I'd work on looming up that new painless wiring kit since everything is working just fine and try to clean up the engine bay a bit more. I'm not great at making things pretty- but it's alright
(can see more of my NEWB welding work on those top radiator brackets...)
Driven it a few times now ... The front clip isn't an exact match (the hood is a bit darker than the rest %) ) but these pictures make it look worse than it is.... I don't want to have a nice whole paint job done because I fear I won't want to take it off road then, yah I'm dumb like that.
Guess that brings us to the end of this stage of the project! Nice to have it back on the road again, since we're in the 90s already....
Thanks as always for checking it out!
Andrew
