Since this has basically turned into my build thread, I thought I'd post a few more photos and updates. I've fallen victim to the slippery slope, and am really tearing into things now!
Took down the rear driveshaft to replace the rear pinion seal, and found a bad u-joint. Removed both drive shafts and had all 6 u-joints replaced.
Got the rollbar sorted out, seatbelt bungs installed, and had it powdercoated.
Cut out a small bit of rust in the driver side footwell and got the patch welded back in. Still have a few more small holes to fill on the passenger side, and will then have zero extraneous holes on the interior!
Also installed the BC Broncos fuel line kit. This was much harder than anticipated, and required a lot of new bending around my proportioning valve. The site was a huge help with photos from other guys who did this, but noone else had the large valve that my '76 came with. Nonetheless, it's all in and complete.
Had a bit of a fiasco trying to powdercoat the wheels. PC did not match well at all, so I had them painted. The bad news is I spent way too much money fixing up a set of old steel wheels, the good news is that they look awesome!
Also since I had two quarts of Wimbledon white, and a slot at the paint booth, I removed the dash and had that painted as well. Also sent my gauge cluster off to Kevin to have him work his magic.
And, since the dash was out, it looked like a good time to remove the steering column and rebuild that. Call me crazy, but I really love the old 3 on the tree! Not to mention the $2.5k entry fee for a nv3550 puts that swap a few years out.
And lastly, with the steering column removed, it was a good time to remove the pedal assembly, clean, seam seal, paint and insulate the drivers side footwell, and paint the pedal asssembly.
Also got the "Alice" mod completed. Huge improvement, love the looks! FYI, the wires need to be swapped on my '76. I didn't read about this on other threads posted here, but when I first tested, the bulb was super bright when parking lights on, and dimmer when flashing as a turn signal. Swapped the wires and it's back to normal.
IMG_0790
That's about it! Will be rebuilding the column and reassembling that and the dash this week and next weekend. Hope to have the interior back together and have it back on the ground and driving again in a week or two.
Thanks for following along!
