I have a 70 EB. Solid but older 302 in it, 3-speed with 37" tires and 4.56's. When I built the axles our speed limit was 55. I'd probably hit the 65 MPH area twice a year. It is OK at 55, not very good at 65. I seem to be the only guy on here that doesn't care for too-low of geared rigs. I should note that our road is now 65 and it is 20 miles each time I drive anywhere one way.
How I use the EB:
For moderate use, maybe 100 miles a week, and then longer trips 2-3 times a year here is what I am thinking about. I should note I do sand maybe once a year and a lot of deep snow 4x4ing.
What I want from it:
Smooth engine, quiet, as good of MPG as can be expected for what it is. Not interested in switching tires, maybe run some 35" ATs in the summer at some point.
What I have to use:
300-6 I'd like to try, an AX-15 swap as well. I do have a basically new crate 302 roller out of a lincoln. Some EFI parts for that. My guess is that either the 300 or the 302 will end up with the FITech system. I doubt I will use the OEM system for EFI.
Assuming that you had a good running 300, the mechanical abilities to install it and the shop etc.
What do you think I will see from a 300-5-speed, 37's and 4.56's?
Convince me why I should run the 5.0 over the 300? I am not a racer, I want quiet, torquey and as efficient as I can.
I'd look at other engine options as well.
Thank you as always.
How I use the EB:
What I have to use:
