DIY Low cost underhood work light
jerry
Bakersfield, CA
Not sure if this should go here or elsewhere.
Was looking at options for underhood lighting. Most were cheaply made, rechargable, overpriced Chinese junk, starting at about $60 for 400ish lumens and 90 minutes of runtime (followed by the same amount to recharge.)
Here's a cheap solution from Harbor Freight. Even here in CA I have less than $30 in it:
1 - 4' 4000 lumen led shop light -$23 (64410)
1 - magnetic hooks - $4
The magnets are strong, the hook part not so much. Will likely drill out the cheap rivets later and replace with better hardware.
Assembly:
* Make sure the lamp is properly wired / grounded. Because... China.
* While I used the included hardware to hang the light to connect to the magnets... It might be a better idea to use something non-conductive.
I don't like the switch - when it fails I'll replace with a toggle.
Outcome -much better than my OG single bulb drop light. I think my mid 50s eyes are going to appreciate this a lot.
Yeah, but think about it. Now you have no excuse to stop when it gets dark. 😁😉
Then again, that light is so good and with such even coverage you might not want to stop!
i3adme
n00b
These days I’m leaning towards rechargeable headlamps. I like the fact light always shines where I’m lookin’. My problem however is that mine is not rechargeable and eats batteries like the Cookie Monster.
Edit:
I forgot to say that I have this light from HF lighting my shop table and it’s brighter than the sun. Been meaning to get another one for the other half of the garage.
daddycreswell
Lebanon, TN
Edit:
Which one did you buy from HF? I bought a 2 pack of 8 4ft length LED lights from Amazon about a year and a half ago. I got one set up, never did get the other set up, glad I didn't because I have had to use the 2nd set as replacements due to the fact that they aren't lasting very long. And Amazon isn't doing anything about it.
jerry
jerry
Bakersfield, CA
Yeah, that's true. But I also see the benefit of being able to get out and work for 1/2 hour at at time too, without having to hassle with dragging out my drop lamp, etc.
Plus, the more I work the more $$ the vendors tend to make. haha!
jerry
jerry
Bakersfield, CA
Edit:
Headlamps are great, I agree. Mine isn't rechargable either, so I can relate to the battery issue.
I really wanted one of those OG, underhood fluorescent lights that plug in but coudn't find what I was looking for.
jerry
jerry
Bakersfield, CA
https://www.harborfreight.com/5000-lumen-4-ft-led-hanging-shop-light-64410.html is the one I purchased.
I'm actually glad I didn't go with something "two row". I'd have to apply sunscreen.
Rustytruck
Yep I pretty much go anywhere with my 4 lamp headlight.it eats batteries for breakfast but that's OK it gets all those toxic chemicals out of the ground.
Pa PITT
Stephenville TEXAS
Edit:
Some of those light can be considered winter heaters. I had one from Home Depot it was 2 500light on a stand. man that thing was brutal
jerry
jerry
Bakersfield, CA
That's probably a good point. I'll have to run for a bit and see how much it gets puts off. Hoping because it's LED it won't be too hot...
sprdv1
REBEL
Assembly:
HF has some very decent and cheap options....
jerry
jerry
Bakersfield, CA
They have some. But I'll tell you, I've been working on her in my hood all day today, and it sure is nice to be able to just fire that thing up and let it run without worrying about recharging batteries. Plenty of light, and it does not heat up substantially. Well worth the $30 I spent.
gnpenning
Bronco Slave
Great idea. I made a couple up for light under my 4 post hoist. I have been looking at putting rope LEDS along the runways, this was easier and works for under the hood as well. I had previously mounted a couple lights low down in the wall which helps, just not the same.
sprdv1
REBEL
Yes sir.. amen to that
