I'm curious if anyone has ever cut off part of the depth of the circle part of the shroud. I'm running a stock 302 with CVF aluminum versions of the OEM crank and water pump pullies, a 3/4" fan spacer with a OEM 7-blade fan (sits about an 1" from the radiator), and an OEM radiator with the WH full circle fan shroud. Everything clears now, but my fan is about 3/4 in the shroud and 1/4 out of the shroud. I'd like to get it closer to what I've read is the recommended depth of 2/3 in, 1/3 out. I (barely) have room to change to a 1/2" spacer to get it further out of the shroud, but was also curious if anyone has experience cutting 1/4"- 1/2" off the circle portion and how they went about it so it didn't look like a hack job. I'm also considering switching to a RD or Griffin aluminum radiator which is thicker and would make this situation worse, so I would definitely have to cut some off if I stick with a mechanical fan.
