You will need to:
Remove the pilot bearing.
Change the blockplate.
Install a flexplate.
Plumb cooler lines/cooler.
Run a vac line.
Find a way to shift it.
Install a kickdown.
vac line is for the trans modulator. need it so it will shift...
don't forget you also need the adaptor from trans into t/c set up
easiest way to do this is to buy a COMPLETE take out.
