Alert! Long-winded reply warning!
As if I'd do it any different. But hey, you've been warned...
I did notice prop valve had a small pool of fluid on it. I tightened Everything down tight again and will retest today/Tomorrow although it was a small amount of fluid so I doubt it was enough of a leak to throw it off
Probably right, but good to check.
If it's leaking out of that rubber boot, peel it back and check the fitting for looseness too. This is an unfortunately too common leak area for some reason. It's a delay valve, and sometimes (if you're lucky) it's just loose. Other times it leaks from the o-ring or seat. A member here just went through this last week and was talking about the fix.
UPDATE.. So i took it out in the driveway (which is SUPER STEEP)... brakes seem to work "ok".
That's maybe almost possibly some good news. But still doesn't sound quite right even for someone not used to Broncos.
Thanks for the clear descriptions by the way
Now if I leave in drive while holding the brakes all the way to the floor and barely push the gas, the bronco will crawl.
Now that's a good indicator that all is not well. And in the clear-descriptions category, by "to the floor" do you literally mean to the floor? Or just pressing as hard as you can?
Because if it's indeed going that far down, you still have air in your system, or a leak is letting air in/fluid out, your pushrod is too short, or as mentioned your soft lines are expanding.
If they're braided, this is unlikely. If they're older rubber, it's very likely.
The last thing that can cause excess travel is the rear brakes not being adjusted properly. But even at their worst, this is only going to make for a little extra pedal travel. Not enough to cause it to go to the floor.
I was able to get the rear to skid a little bit.
Again, a tiny bit of good news in the mix.
I crawled under and verified the knuckles. There is about 1/8 of an inch between the caliper and the knuckle.
Sounds good. As long as you can see that 1/8" of daylight between the components, you're in good shape.
I am going to bleed the brakes again. Maybe air got in the system with those little leaks I had.
Very good idea at this point. Sorry you're having to go through it, but if your description of going to the floor is correct, there is very possibly some air in the system
I think part of the issue is this is my first bronco and up until this point I've never driven one. So have zero clue what to expect.
I think this is a key factor. But it might not be the only thing at work here either.
You are still fighting a larger diameter piston in the master than is normal without a booster of some kind. And you may still have something wrong. It's just very hard to tell from here yet.
I'm a fan of manual brakes in fact, and that's how my '71 is set up. Albeit with a 1" master.
And there are other members here using your exact setup and like it.
But it's still a compromise using the larger master. Good firm pedal feel and short travel, but you have to push harder to get it to stop.
Not that I don't appreciate a boosted setup, but after spending years on the trails and dealing with stalled engines where boosted brakes would be useless, a boosted setup is last on my list.
Heck, I just graduated to power steering!
Not just Broncos, but is this also your first older truck in general with manual brakes? As you suspect there is a huge difference in feel and power between any modern car or truck and a heavily modified older manual brake utility vehicle.
The key word there is modified. As in, larger tires, larger calipers and master cylinder.
If stock size master and stock size tires, the brakes you have would work "better" to a point and maybe even passably well. You'd probably be able to lock them up a little easier perhaps, but you'd also probably still feel the brakes were sub-par to what you're used to. Because in fact they were!
But you should still be able to expect a reasonably safe driving experience as well.
As a comparison, with that same master and brake setup, with those same 33" tires, adding a hydro-boost setup would probably push you towards the windshield when you hit the pedal.
Even the factory style vacuum boosters are not that impressive compared to the hydro-boost, or most other more modern vehicles. The cost is more impressive too though, as you've probably seen.
And vacuum boosters are also still perhaps better suited to the stock 1" bore master than the 1.125" size. More pedal travel, but easier on the leg muscles.
My newer rig (the '68) has a vacuum booster and 1" bore master, and it's not all that impressive either. And that's with just 31" tires!
Can't lock up the tires when it's cold at all, but it does get a little better when warmed up. Might be the pad material in my case though. Just not sure yet because I have not messed with it enough.
So your larger piston is still an advantage to gaining a firmer pedal with the larger size of the front brakes that you have. Just takes more leg pressure.
But pedal travel should be negligible too. No way it should go to the floor.
Maybe it's normal. But I'd think If I push the pedal as far as it goes I'd have a lockup.
It's not really normal, but it it's not uncommon either with larger tires. And it is something that others do deal with too.
As mentioned a few members here are using your exact setup and give it good reports. But they may be coming from a different place in their vehicle experiences too. Or maybe they're just young and have strong legs! How are yours doing these days?
I know I don't enjoy it as much as I did when I was 25.
But for that heavy-pedal reason I would say most who are sticking with manual brakes also stick with the stock size master.
Which brings me to an important question. How did you come to choose that particular master? Did we recommend it, knowing that you were sticking with manual brakes? Or were we not aware of your setup exactly perhaps? We sell a lot of that master for all the right reasons, but not as often for manual brake systems.
Just curious because I don't want us to ever steer someone down the wrong path for that person in particular. Every customer is different, but we should know how everything is going to work and let them know to the best of our knowledge too.
Let me know.
And we still have to keep the proportioning valve in mind at this point too.
Thanks. Hang in there!
