Ok so im sure some people have talked about this but I figured if start a new thread.
I have the stock power steering unit out of my 76 that was working fine just had a very slow drip but im doing a full restore so im obv going to get that taken care of. What are the best options?
-Just have mine rebuilt and maybe have the ratio switched if need be but arnt the 76s factory 4 turn?
-just buy a new 4x4x2 or rock crawling box
-get the f100 2wd box or the f250 box and use the adaptor plate
If I get mine rebuilt after doing some research I found www.redheadsteeringgears.com and talked to them a d sound like they know what their doing and can switch the ratios and clean and paint up your box to and can have it done in a very short time I think was around $350 if the box wasnt junk or a $100 more if it needs a new shaft. This is a pic of the box after their done
I will be running HYDROBOOST if it matters and running DOM gm 1 ton steering linkage and 33 tires. Just trying to see what you guys have had best luck with.
