I've heard of this ever since we've been doing 3G swaps, but have never run across the need myself. At least not yet.
Have installed quite a few 3G and 4G alts without a light and have not had an issue. However, I want to install lights on all the setups anyway, just as an additional warning.
In the case of a lamp, as opposed to a resistor by itself, it was my understanding that it's not to put resistance into the wire, but to keep the alternator working in case the bulb blows out.
So if you do have a dash light, always use a resistor loop to fend off that problem. If you don't have a lamp, I guess it's hit-or-miss?
What alternator did that t-bird setup come with Arikilen? Is it a 2G or 3G? Standard or something exotic? Just curious. I don't want to forget about this the next time I hook one up and it doesn't work!
